Order Ford 8N Parts Online
1947 8N Clutch
Bryan Campbell
09-22-1998 12:07:02
I have a 1947 8N that I'm very pleased with, but
the clutch seems to stick about halfway down,
which requires me to pull it back up with my foot
before the clutch will engage. This is a real problem
when loading or unloading a trailer and quite a pain
when bush hogging. Any help would be greatly
appreciated!
Thanks in advance,
Bryan Campbell
Fargo - Faster to do it by hand when ground is wet
05-25-2000 07:31:47
 Re: Re: Re: Re: Post Pulling in reply to Ed Gooding (VA), 05-25-2000 05:36:49
Wait till it rains. Wiggle them back and forth and all around. Pull them up and out. Use your legs, not your back.
I have removed hundreds this way. Takes about 30 seconds per 4x4 post. I am doing 50 this way every weekend.
No back problems.
Mark
E.Allison
09-23-1998 11:32:16
 Re: Re: 1947 8N Clutch in reply to E.Allison, 09-23-1998 10:10:08
Sorry, I didn't read your post carefully. You said the clutch will not engage until you pull up on the pedal. This is not the return springs. As others have said its the linkage or pressure-plate. EEA
TimK
09-22-1998 12:59:34
 Re: 1947 8N Clutch in reply to Bryan Campbell, 09-22-1998 12:07:02
I concur that it is probably a broken clutch plate spring or a broken or bent clutch arm, unless there is some obviuos binding on your clutch footpeddle or linkage. If you have to split the tractor, while your in there may as well replace the throw-out and pilot bearings and the friction disk and take a good look at the ring gear and flywheel.
Nolan
05-25-2000 03:45:59
 Re: Help with short winded 8N in reply to Paul, 05-24-2000 21:46:48
Sounds like a classic case of restricted fuel supply. The engine takes in more gas then is getting to the carburetor and goes lean. You choke it to compensate, eventually the float bowl gets so low the engine dies. Gasoline continues to trickle in from the fuel take, and by the time you get done examining other things the carburetor float bowl is once again filled up. The tractor then starts, and the cycle begins anew.
Work your way up from the carburetor to the tank itself examining for restrictions and blockage.
