Order Ford 8N Parts Online
8N stalls after it gets hot, will not fire for 20 min. or so.
Gremlin
09-19-1998 19:48:26
1950 8N, has fire, gas going to carb. no fuel on plugs after cranking. If you wait 20 min. or so it will fire up and run fine. VAPOR LOCK?... IF SO WHAT TO DO....I rebuilt carb lately. THANKS
Dell (WA)
09-21-1998 08:19:27
 Re: 8N stalls after it gets hot, will not fire for 20 min. or so. in reply to Gremlin, 09-19-1998 19:48:26
Gremlin..... Denfinately NOT vapor lock, gravity feed from fuel tank. I would suggest considering the following: coil, condenser, and most obscurely the ignition switch can get get gunked up inside and cause the same problem. Good Luck..... .Dell
Kim
05-24-2000 08:12:38
 Missing Posts in reply to Gremlin, 09-19-1998 19:48:26
Bob Gaddis
09-19-1998 20:04:51
How long will it run after it cools off and you recrank it? Does it still quit after it gets hot again, or does it continue to run until you decide to cut it off?
Eric Zimmerman
05-24-2000 13:21:41
 Re: 6V to 12V conversion in reply to BULL, 05-24-2000 10:45:29
Try the following link, will give the details you are looking for.
photofarmer
05-24-2000 14:22:39
 Help!Flat front tire problem in reply to BULL, 05-24-2000 10:45:29
