3 Point Weld
Steve
09-19-1998 12:55:25
The hold down bolt hole for the spring is broken out and I want to know if the case can be welded on. The top point of my hitch isn't working too well when all it is attachto to is the spring
Thanks in advance.
Don 8N143633
05-26-2000 03:11:14
 Vacuum Testing an 8N? in reply to
Steve
09-21-1998 15:58:20
 Re: 3 Point Weld in reply to Steve, 09-19-1998 12:55:25
Sorry that I wasn't more specific Dell and Bob.
What I was talking about is the main control spring for the top link of the hitch. Is the transmission case weldable? If so with what?
The spot where the yoke attaches with a pin to the transmission case is broken out and all of my top end weight is riding on the spring itself. Not much control either.
I hope I was a little more graphic with my explanation. I was in a hurry the other day.
Thanks for bearing with me guys.
Dell (WA)
09-22-1998 07:27:02
 Re: Re: 3 Point Weld in reply to Steve, 09-21-1998 15:58:20
Steve..... .Ah-ha.....now it makes a little more sense. I believe you are describing what I would call the "ears" of the differential case that the hydraulic draft control spring (the big spring) is "pinned" to. Anyway, I believe the differential is "cast iron" and I believe that cast iron is weldable. But I am NOT a welding expert. Not much help I'm afraid, but it should be repairable by building up weld and then re-drilling/boreing the hole. You might try something like "JB Weld" if welding is not an option. Good luck..... Dell
Salmoneye
05-24-2000 13:58:34
 Re: Yall Confused? in reply to Tyler(MD), 05-24-2000 13:47:55
I'm not confused. Look at it like this: If we as users of the 'New' format had issues, Imagine what a headache Kim and the others on her end must have had trying to 'improve' what they were given by the software vendor! I think that it is obvious that they were having a much harder time with the new system than we were, or could even imagine! I, personally, am pleased as punch to see the 'Old' format return. The 'New' format had its' plusses, but I feel that they were far outweighed by the negatives. Just my opinion though...
Paul II
Bob Gaddis
09-19-1998 20:25:57
What, exactly, are you talking about? It would be easier to help if you could be be a tad more specific.
