Order Ford 8N Parts Online
8N cuts off when hot , wait 20 min. runs fine..
GREMLIN
09-19-1998 12:07:39
1950 8N, has fire, has gas flow to carb., plugs dry after much cranking. If you let it set for 20 or so min.it will fire up fine. VAPOR LOCK?
WHAT TO DO, THANKS
hammer
09-20-1998 14:35:43
 Re: 8N cuts off when hot , wait 20 min. runs fine.. in reply to GREMLIN, 09-19-1998 12:07:39
I had the same problem. See my 9/20 response as to why you "May have spark" . If all else fails , repolace the coil.
CURT in Southern Indiana
09-20-1998 06:37:05
On my '52 8N, I experienced a similar problem. After some mowing, the tractor would start missing under load & eventually die. Playing with the choke helped a little but also helped isolate my problem. My problem was fuel starvation. Rust and cooruption in the gas tank had pretty well coated the screen in the sediment bowl. I cleaned it and the tractor ran fine for a couple of days then the same old problem re-occurred. Had more crud on sediment screen. I drained gas tank and took off shutoff valve to reveal considerable additional rust, dirt & debris. I flushed tank with gas and put it all back togehter. To be safe, I disconnected the gas line from the carb and re-cleaned the inlet screen there.
Viola, so far, no more chug, chug, chugging.
Hope this helps your problem. Goof luck
Gremlin
09-19-1998 20:03:41
John/Cadillac, I have fire to plug during this down time.Gremlin
Cadillac Gary
09-19-1998 17:25:44
Gremlin, I agree with John. I think your coil is breaking down when it heats up. Let us know what another coil does for you. G/L Cadillac Gary
Gremlin
09-19-1998 20:13:51
 Re: Re: 8N cuts off when hot , wait 20 min. runs fine.. in reply to Cadillac Gary, 09-19-1998 17:25:44
I have fire to plug during this down time. G.
Gremlin
09-19-1998 20:13:46
Gremlin
09-19-1998 20:13:23
John Regan
09-19-1998 13:05:11
COIL!
