I did read your previous reply -- thanks for staying with this Zane. I was finish mowing and got stuck moving from 2nd to reverse -- I did not hit anything. But, today I split the tractor so I could loosen the gears, and I found 1/2 a tooth broken off 2nd gear. It had jammed between other gears -- I'm not sure which because it fell out before I found it (I did recover it, too). I probably shifted from 2nd to reverse too quickly -- that's my guess. I've carefully reviewed every gear and tooth that I can see -- while I know that's no guarantee of further damage, I can't find any. Here's where I am now: I'm beginning to think that I don't know where neutral is. I've been putting the shifter on, seeing if I can shift, and if I can (often I can't ) starting it up and letting out the clutch and shifting some more. Most often after I put the shifter on, I can't shift. But the shift plates and forks are free. Sometimes I put the shifter on and can shift, so I start it up and I either can't shift, or I can once or twice and that's it. Usually the 2nd/4th fork is hung up -- I'm getting pretty good at freeing it. With the tractor still split, shouldn't there be some combination that allows me to spin the gears by hand without turning the output shaft? I know to put the shifter back on, all three slots need to be lined up -- the two in the shifter plates and the one in the top shift rail. I believe I'm doing that, but something goes awry after I bolt the shifter down and try to shift. And yes, I do have the detent ball & spring in place for the top rail. Any more thoughts? Thanks again for your help.
