8-n Hydrolic problems
Jeff
04-30-2000 20:30:17
I have a problem with my 52' 8-n. The hydrolics will not lift by using the touch contol lever.
However, with the touch control lever all the way up and the selector lever in the horizontal position, they will lift when I push the selector lever down past horizontal. While plowing, the hydrolics work fine with the touch control lever, I assume this is because the plow is putting preasure on the toplink, but when I stop at the end of a pass and try to lift up the plows, nothing happens unless I go through the process I described above.
Please Help
ZANE
05-01-2000 05:38:44
 Re: 8-n Hydrolic problems in reply to Jeff, 04-30-2000 20:30:17
I have developed a manual and the adjusting jig so that the 8N lift can be repaired and adjusted in one operation and if the instructions are followed be the number it will work the first time out of the shop.
Email me at [email protected] If you want more information about it.
ZANE
