12V Delco Conversion HELP!
Dave (Jubilee)
04-30-2000 09:57:21
I am converting my Jubilee to 12V, but having a fit trying to adapt the alternator, can anyone out there help on how to construct a mount or tell me where to buy one, I want to mount it where the generator was mounted and still keep the belt running straight.TIA
AL@NC
04-30-2000 12:02:21
 Re: 12V Delco Conversion HELP! in reply to Dave (Jubilee), 04-30-2000 09:57:21
'----- -----'----- -o----- ---o--
Dave, this is the best I can do for a picture for you. The horizontal ----- is flat stock 6 1/2" long drilled o to bolt to the block at the original mounting holes. The two uprights on the left |.....| are brackets made of flat stock welded on to the horizontal to accept the altinator and positioned so it will have the proper alignment. If your exhaust pipe is in the way you should be able to loosen it and/ or the muffler to position it forward to get your clearance. I had plenty of room on mine. I also had to extend the belt tensioning brace to tighten the belt. Good luck, Let me know if I can help you further. I can take a photo of mine and e-mail it to you but it will take a couple of days.
Dave (Jubilee)
04-30-2000 15:15:38
 Re: Re: 12V Delco Conversion HELP! in reply to AL@NC, 04-30-2000 12:02:21
I would appreciate a pic, i was thinking of 2 strips of 1"X1/4" bar and bend 90% on the ends but have no idea if the mount would stay tight on the block. Thanks.
