Order Ford 8N Parts Online
12 volt wiring on a 8N
Dick Winter
04-28-2000 09:19:54
I purchased a 8N tractor and it is wired for 12 volts negative ground using a generator and a voltage regulator. When the tractor was painted I believe it was not rewired correctly. The tractor started and ran fine for a while. The ampmeter shows it discharging and the battery ran down. Could someone help with a wiring diagram using a 12 volt generator and a voltage regulator?
STUMP PULLER
04-28-2000 12:42:16
 Re: 12 volt wiring on a 8N in reply to Dick Winter, 04-28-2000 09:19:54
TRY THIS FOR A GUIDE. CLIK ON THE URL BELOW. YOU NEVER KNOW WHAT IS IN THESE OLD TRACTORS. SOMEONE MAY HAVE JUST PUT IN A 12 VOLT BAT. YOU NEED A 12V REG ADJUSTED TO PROVIDE 14.7 VOLTS AT THE BAT AT FAST IDLE. GOOD LUCK
