3-pt. hyd.
Stan, N/W Mi.
04-26-2000 17:38:49
What is happening?? My 1952 8-N tractor 3-pt. system is not working like it should. I have been disking my field w/ the 8-n, every once in a while it rises higher then normal, hangs up and will not lower when i push the lever down. after i shut it down it will slowly drop to the ground. So tonight it seems to be getting worse,(Happens more often) Any one with an idea??
ZANE
04-26-2000 19:19:04
 Re: 3-pt. hyd. in reply to Stan, N/W Mi., 04-26-2000 17:38:49
Sounds to me like you may have some dirty oil and stuff in the hydraulic reservoir. If there is grit etc in the hydraulic oil it will cause the control valve to stick and not be able to lower.
I would drain and flush out the hydraulic reservoir with kerosene by pouring it straigt through the fill hole and out the bottom several times and then do it one more time with good clean kerosene. let drain for some time then fill with new 80 w or 134.
