Loader pump shaft
JB
04-25-2000 09:11:35
After removing the loader from my 8N last night I was left with a problem. How do I remove the shaft that was used to drive the hydraulic pump? I can't see any set screws on the drive coupler by the crank shaft. Any ideas would be apprectiated.
JB
Nolan
04-25-2000 11:41:08
 Re: Loader pump shaft in reply to JB, 04-25-2000 09:11:35
Wagner type? My Wagner has the shaft screw into the coupling plate that "fingers" into the crankshaft pulley. Left hand thread! Involves quite a bit of profanity before it will unscrew.
Levon
04-25-2000 10:51:53
I'm dealing with the same problem on my 8n. I want to replace the belt, but can't get it past the shaft and plate. I was told (although I haven't tried it yet) that the shaft should screw into the drive coupler. It is REVERSE THREADED so to unscrew it you need to turn it to the right or clockwise. Like I said, I haven't tried it yet, so please let me know how it turns out.
Hope that helps
Levon
