3 point hiccoughing
JimmyJack
01-20-2002 22:49:08
My 3 point on my Jubilee started hiccoughing when is gets hot. Any easy troubleshooting?
ED-Illinois
01-21-2002 07:09:51
 Re: 3 point hiccoughing in reply to JimmyJack, 01-20-2002 22:49:08
Don't know if this will help, but a few weeks back Dell posted a response to a guy who had the same problem on a 8N. Dell's advice was that when the fluid was cold, it was thicker and thus more forgiving to loose or weak seals.
I am not sure of the NAA setup, but on the 8N, the tranny plate with the dipstick should be removed, and the lift operated. While working look for leaks - that might tell you what is wrong.
Also make sure you have the right fluid in the tranny.
Mark Hendershot
01-21-2002 06:21:47
What is getting hot? The engine, Fluid, Bearing Shims on the lift arms, Transmission, pump housing need more info for answers. Thanks, Mark H.
