Order Ford 8N Parts Online
8N Position Control Help
MB
04-24-2000 09:01:34
My lower links drop about 6 1/2 inches when I switch to constant draft from position control(with no weight on them).In the book it says the position control spring is too long. The question is, how difficult is it to adjust the position control spring? I would like it to work correctly for plowing and disking. Also, is there anything else I should adjust while I have the cover off? Any help or advice will be appreciated.
bg
04-24-2000 11:04:03
 Re: 8N Position Control Help in reply to MB, 04-24-2000 09:01:34
The book gives measurements and procedures for the adjustment of the PC spring, However, it would be better to use a jig(Zane has a model for sale) to adjust the linkage. While you habve the cover off, inspect for any worn or broken parts, especially the cam follower pin which is a major part in the hydraulic function. Inspect your piston and lift cylinder for wear and amage. If the cylinder is scored, you can hone it and replace the piston with an NAA piston/o-ring combo.
