Live N hydraulics
ZANE
01-19-2002 10:55:31
If'n this thing does like I think it will you will also be able to tap into the hydraulics and have any number of two way open center control valves for use with auxillary implements such as a front end loader or maybe a hydraulic top link etc. Preferably with a relief valve but not necessarily mandatory. Lots of possibilities!
All without having to tie the lift arms down and still be able to use the three point hitch.
ZANE
01-20-2002 08:03:22
 Re: Live N hydraulics in reply to ZANE, 01-19-2002 10:55:31
Initial test proves my theory that the N can be equiped with live hydraulics without any change to the original lift components.
Initial tests also proves that air is a heck of a lot faster than hydraulic oil. When I appied air from my compressor to the system that I have plumbed up for testing the theory the lift nearly threw my field cultivator through the top of the shop!!! :O) Don't try this at home!!!
plan do some more testing tomorrow but not with air!
ZANE
01-19-2002 17:28:04
Hey I've got a selfish motive for this idea. I have one of the old Ferguson systems too. Get to the end of the row plowing and then clutch and put in neutral. Let out on the clutch and raise the plow. Put it back in gear and turn around and then it's back the other end and repeat the same shift shift shift clutch clutch clutch. It tires you out!
DON TX
01-19-2002 16:21:58
How many pennies do I need to save up??? DON TX
makedo
01-19-2002 12:20:36
sign me up please.
Rob9N
01-19-2002 13:37:11
 Re: Re: Live N hydraulics in reply to makedo, 01-19-2002 12:20:36
I'll take one and a T-shirt.
Salmoneye
01-19-2002 13:48:35
 Re: Re: Re: Live N hydraulics in reply to Rob9N, 01-19-2002 13:37:11
I'll take two and give one to the guy down the road for his N, but...
I get to keep both hats and the bumper stickers!!!!!
davido30093
01-19-2002 11:48:17
Just waiting for you to say it is ready so we can start placing orders.
Greg
01-19-2002 11:16:08
OK Zane... you've got me droolin'! (-;
