Darrien- Short answer is "yes", but... A neighbor had one on the back of a TO-20 Ferguson. I hit him up to borrow, rent, or whatever deal was possible, for a little job I had. My inquery seemed to "rub a sore spot". I got the impression the outfit was long on looks and short on getting the job done. Recently, when I drove by his place, I see that back hoe outfit mounted some kinda much bigger tractor but don't know what it is. I took care of my little job (install a driveway culvert pipe) with a case of beer for another neighbor, that has a JD crawler endloader. Read on if you are looking to getting into backhow work. Ursuala, please speak up with some lessons learned here! You are in a very good position to "get it right from the git-go" as to your needs. With you talking about back hoes and trenchers I'm inclined to recommend you save your money and watch for deals on stuff that was built to operate as a complete system, rather than getting ensnarled with stuff that wasn't designed to work together from both sides. Keep in mind that the N series was designed to be a 2 plow, 2 row, row crop tillage tractor, with utility as an assumption. Think it thru, talk with people that use them things. Then do what seems right for you. After that, post your findings and recommendations for others! Good luck, IHank
