While I am neither hot for or against 12 volt conversions, my 9N has one and has worked well for years. I also have converted a couple of JD working tractors. If yours is not working well, it could well be that whoever had it before really cobbled it up (this, by the way, is not unique to 12 volt conversions-there are a lot of 6 volters cobbled sufficiently such that they don't work either). There are a number of sites that post very good drawings as well as one that lists a complete conversion. My suggestion, is that if you have a little time, pull up a couple of these and compare against your tractor. If your tractor is true "spagetti", remove all the wiring and start over. There is really no magic to this. If you are unsure, check with some friends, one will probably be able to help you. You should be able to completely strip and rewire this in about a half a day, a day at the longest. Finally, 12 or 6 volt, the 9N, 2N, and early 8N's with front coils suffered from moisture problems, especially with puller fans. My suggestion is to remove the coil and check the gasket. When you put the gasket back on, coat it with dielectric silicone grease. Also, once the whole thing is back together and dry and running, liberally spray the distributor and wires with some ignition water proofing spray available at auto stores. I think you will find, once you get your charging and ignition wiring in order, that this will minimize the wet weather blues. Just my opinion. JerryU
