1960s ford jubalee skidstear
matt lanphere
04-21-2000 07:53:06
I am looking for parts and don't know where to get them can someone help.
ZANE
04-21-2000 20:41:23
 Re: 1960s ford jubalee skidstear in reply to matt lanphere, 04-21-2000 07:53:06
There was a skid steer tractor named a "Bellmar" It did not steer with steering clutches as it should have but with brakes alone. When the brakes get bad you just don't steer but go in a straight line and there are very few jobs that you can do going in a straight line. The rear end and steering mechanism is from a David Brown tractor and the brake linings that are sold at Tisco and several other suppliers.
You should measue the diameter of the discs and the number of splines and the inside measurements of the spline before ordering them. They are slightly thicker than the ones originally used on the Bellmar but can be used by shimming out the brake housing to accomidate the difference.
I would assume the differential is DAvid Brown also. From the rear of the transmission to the front of the hood everything else if Ford.
Russ in SoCal
04-21-2000 22:47:47
 Re: Re: 1960s ford jubalee skidstear in reply to ZANE, 04-21-2000 20:41:23
Zane, try "search this site" for "spaghetti."
RICK
04-21-2000 19:40:18
Don't know what you have. Jubilee was only made in 1953 as a tractor. Did they also make a skid steer loader with the name? If it's a Ford call Palmer Fossum, if anybody knows he will. 507-645-8095
