 Anyone who has a 600-800 -900 series Ford has probably had problems with the fuel valve on the fuel tank. I know I've had mine off many times trying to correct the repeated leaks that develop.I'm now celebrating a year with no leaks. This is how I finally beat that damned contraption: 1.-Drill out the rivet being pointed at in the pic. It holds the valve in the housing. With the rivet removed the valve will screw out of the body. 2. - Replace the O-ring on the valve. If your valve is leaking, the O-ring will be worn down flat/flush with the valve. 3-Clean the rust out of your fuel tank and seal the tank if needed to prevent future rust. Even though there is a screen on the fuel valve, a very fine dirt/rust grit will pass through it and deposit an abrasive film in the valve, which causes fast wear to the O-ring. 4.-Use a small buff on a dremel tool and some buffing combound to smooth the inside of the housing where the O-Ring rides. The machining on this part is coarse and causes wear to the O-ring unless smoothed up. 5. Cut down a machine screw to replace the rivet, reassemble the valve and JB Weld the screw in place. The screw won't leak and is not all that hard to remove for a future rebuild. Since redoing the valve and sealing the tank, my valve works very smooth and no more leaks. Used up a lot of good cuss words on that valve before I got it to behave. I was cleaning out my jpeg folder and came across this picture, I know alot of the N-owners also have 100 series tractors and thought you might find this info useful. Funny thing - I've never had a bit of trouble with the valve on my 8N. Must be a better design. FWIW - Mark
