12 VOLTITICE
Scott
01-01-2002 11:53:27
If anyone else converts their tractor from 6 to 12 volts instead of fixing the real problem and seeing all the headaches it causes on this forum, They should see a doctor first thing in the morning.
Norman
01-01-2002 22:25:36
 Re: 12 VOLTITICE in reply to Scott, 01-01-2002 11:53:27
One of the best things I did to my 8N was to convert it to 12 volts. No problems, ever!
If it is done right, there should be no problems.
I converted after a full engine rebuild, so it wasn't realy needed. But the overall convenience has been more than worth that little extra effort. I also have been able to retain the original ignition system, and can jump her with any 12 volt battery or vehicle, but never have had too. I can charge her with a 12 volt charger, and I can use all 12 volt bulbs. I have more light now and can run more of them than with my new 6 volt battery. I also added a meyers snow plow on the front with a 12 volt hydraulic pump that runs the plow and adding it and running it is no problem. I have never had a problem starting her in cold winter weather since I have converted to 12 volt. I bought a 12 volt internally regulated GM alternator for under $50.00, and have never had a problem with it. I still have the 6 volt charger on a shelf. Any takers?
RussMO
01-02-2002 15:23:44
 Re: Re: 12 VOLTITICE in reply to Norman, 01-01-2002 22:25:36
Very well put. I did the 12Volt conversion per instructions from this website, and it certainly has helped in the areas you mentioned.
12 volt reasons . . . Dell (WA)
01-01-2002 23:02:49
Norman..... .thankyou for listing some good reasons for converting to 12 volts..... ...Dell, a 12 volt advocate for the right reasons
Bob in NY
01-01-2002 15:31:23
Before I knew better (before finding this site) I just stuck a 12 volt battery into my '46 2N. I know better now, but still keep it in, without changing any ballast resistors or coils. Been running it that way for around 9 years now. The old generator bracket cracked, and I used an 12v alternator as an idler pulley. After about 7 years that way,,,charging the battery externally once a month, I finally hooked up the alternator to actually charge the battery. She cranks over within two R-R's every time, summer or winter. Like you implied, don't mess with a good thing,,,it works for me! Bob
uh . . . Dell (WA)
01-01-2002 15:05:30
Scott..... ..You've made an interesting observation, but the problem with most 12 volt conversions, is ya only hear about the mucked up'uns done by the electrically challenged.
I'm a 12 volt advocate for the right reasons, that said, I haven't found the reason to convert my eazy starting 6 volt '52 8N and I know how to do it right and why..... ...Dell
Patrick md. va.
01-01-2002 14:27:43
I agree Scott! I have a frame off restored 1949 B1B Dodge pickup. I use it all year around and it is 6V and works great! I also have use of my uncle's 52 cub cadet. Also 6V and works great. I have a '44 2n also 6V and works great all year. Sometimes in the winter it doesn't get started for 2 months at a time. It never lets me down!
you think so?..................swavo
01-01-2002 13:51:55
I'm not into blanket statements for causes or cures. Again if I might so bold as to quote another"for the right rerasons". A twelve volt conversion is not the panecea for your starting woes, however there are many good reason for a twelve volt conversion like bright lights for those special night maneuvers,running twelve volt accessories like pumps, sprayers or the blender for making frozen concoctoins on those hot days.
mike
Dave-NJ
01-01-2002 13:50:33
Bought my 2N four years ago with a one wire alt, no problems. It can be done right, and I do like 12 volts. Dave.....
roperboy
01-01-2002 12:41:29
completely rebuilt my 2n and left it 12 volt. dont have any problems. however it was a cobbed up job before the rebuild. got new 1 wire alt and wired it right. had the local starter shop go into the new alt and fix it to where it excites around 800 rpms.
