8 n 12 volt conversion
Mike
12-31-2001 15:55:10
Help 8 n starting problem . My dad has a 8 n that has been changed to 12 volt . we are considering ordering a 12 volt coil. Also if we do this and do away with the resistor .Do we need a different condesor . Thanks Mike
T�l�r (M�)
01-06-2002 04:04:42
 Re: 8 n 12 volt conversion in reply to Mike , 12-31-2001 15:55:10
tst
Dell (WA)
12-31-2001 16:08:58
Mike..... ...6 volt ignition condensor is good for 200 volts, so no you don't need to change the ignition capacitor on a 12 volt conversion.
BE AWARE, even using a 12 volt frontmount ignition coil, you still need some sort of current limiting resistor or you'll be replacing your 12 volt coil in about 10 hrs. Use a 0.5 ohm 10 watt resistor.
I have answered this same question twice in the past 2 days. Do some brousing and read about it so you understand the situation. If'n you still don't understand, please re-post..... .Dell
oslo nc
12-31-2001 18:13:23
 Re: Re: 8 n 12 volt conversion in reply to Dell (WA), 12-31-2001 16:08:58
Dell! Thank God he had the smarts to ask on this site before he learned the hard way. I'm glad did ask that question. I might have tried doing that myself. I know better now. Thanks for the safety tip.
oslo NC
