12v coil...need a resistor?
Dave G.
12-26-2001 16:31:19
Hi,
I recently swapped my 52 8n 6v generator, coil and voltage regulator with a 12v gen/coil/vr.
Do I need a ballast resistor if I'm using a a newer 12v coil with my original distributor and points? I'm not having any problems, but someone mentioned to me that I'd eventually burn up my points. I thought that was only if I used the original 6v coil without a resistor.
Thanks,
Dave
bj/8N/mt
12-27-2001 04:49:58
 Re: 12v coil...need a resistor? in reply to Dave G., 12-26-2001 16:31:19
Part of the joy of twelve volt conversions is there are so many ways to do it. Some of them even work. All that I know about mind reading I learned from Dell and Claus but let me take a couple of wild guesses.
First, if you canabalized an automotive twelve volt system for the parts go back to the same system and get the balast resistor to match the coil. If you bought a coil over the parts counter go get the parts person to find a resistor to match. If you have a coil that needs a resistor and you run it without one it will last maybe as long as ten hours before it turns to toast.
Next guess--if you grabbed a generator off something like a V 8 Chev check the pulley sizes against the flathead. On a V 8 the pulleys will be sized to not over speed it at five thousand engine rpm which will result in little or no charge at tractor engine speeds.
Or just go in and fix the trouble that caused you to start converting. Neither of my six volt 8N's missed a start last winter in Montana. You can do a six volt tune up--new two gauge cables, wiring harnass, generator rebuild, wire brush the connections--and have money left over before you even pay for a twelve volt battery let alone the conversion parts.
Your mileage may vary
DaveG.
12-29-2001 20:07:00
 Re: Re: 12v coil...need a resistor? in reply to bj/8N/mt, 12-27-2001 04:49:58
Thanks for the reply. Miss Cleo has nothing to worry about, because your mindreading skills ain't working ;-)
-The 12v coil was one I had on the shelf.
-The generator came from a chevy 235 6 cyl.and charges fine on the tractor (although throttle has to be nearly full).
-I have no $$$ into this conversion. Even had the battery on hand. I can burn up five sets of points before I spend the money a new 6v battery would have cost me.
Just funnin. I do appreciate the response.
DaveG.
bj/8N/mt
12-30-2001 05:22:20
 Re: Re: Re: 12v coil...need a resistor? in reply to DaveG., 12-29-2001 20:07:00
No offense taken
Just one favor to ask
When you post trouble questions--and I would bet you are going to have them--post what type of twelve volt system you have cause most folks are going to assume an alternator and other things that don't apply.
You could fiddle with pulley size on that generator to get more kick at idle but may not be worth the trouble if you battery is staying up.
Dell (WA)
12-26-2001 23:26:37
Dave..... ...no...yes...and maybe. Always hafta go thru this same song and dance for all you electrically challenged persons. It depends upon what "12 volt" ignition coil yer parts person sold ya.
Some are designed for true 12 volt operation, no resistor needed. Some are designed for ballasted 12 volt operation. If'n designed for ballasted operation, it needs a ballast resistor, plain and simple. And donna ask me what value ballast resistor to use, cuz its a deep dark secret, known only to yer parts person.
I flunked mind reading, just ask my ex-wife, BUT I'll give ya some ballpark guesstimates...if'n true 12 volter, primary resistance will be about 4-5 ohms. If'n a ballasted 12 volter, primary resistance will be about 2-3 ohms.
And if'n its a true 6 volt coil, primary resistance will be about 2-3 ohms (isn't that interesting? wonder why?). Secondary resistance will be about 5000 to 10000 ohms in all cases, so you should have no doubt which ignition coil winding you are measuring.
You can get a passable volt/ohm meter at yer local mega-hardware warehouse store for $20 cheep or $200 at a highend autoelectronics emporium. Its yer dollar, but you can always use one for trouble shooting.
That said, ohm meters are not too accurate at low ohm reading (has to do with ohm meter design) so if'n ya gotts a 1.5 ohm reading, well guess what, thats close enuff to 2 ohms to be considered a 12 volt ballast required 12 volt coil. OR if'n ya read 5.5 ohms, ya probably gotts a real 12 volt coil. BUT if'n ya reads 3.5 ohms, donna know whats ya gotts, but if'n ya ain't burning ignition points, then ya probably gots a true 12 volt ignition coil and leave it alone.
As one N-Board member likes to point out, there are many ways to convert to 12 volts and some of 'em even work..... ..Dell
DaveG.
12-29-2001 19:51:09
 Re: Re: 12v coil...need a resistor? in reply to Dell (WA), 12-26-2001 23:26:37
Dell,
Thanks for the reply. I already have a nice multimeter handy, so I'll put it to good use with the information you gave me (which I've saved).
The 12v coil is from an 85 Mazda GLC (had the part on my shelf). Maybe I'll call the parts store and ask their computer if it needs a resistor.
Thanks again,
DaveG.
How many X-Wife's Ya Got?
12-27-2001 02:01:17
bet ya got a bunch of X's
1 too many . . .
12-27-2001 09:06:07
 Re: Re: Re: 12v coil...need a resistor? in reply to How many X-Wife's Ya Got?, 12-27-2001 02:01:17
32 yrs down the drain. . .
Jim K
12-26-2001 17:04:50
Dave I was mostly right, I did a little research
Because I like to learn this stuff.
Try clicking on the link below.
Dave G.
12-29-2001 19:35:18
 Re: Re: 12v coil...need a resistor? in reply to Jim K, 12-26-2001 17:04:50
Jim,
Great reply!
Thank you for the help. I appreciate the extra effort and the link, too. I've got it bookmarked.
DaveG.
Jim K
12-26-2001 17:03:13
Jim K
12-26-2001 16:48:53
Dave the answer is yes, unless you know for sure that your coil is designed to run on 12 volts,reason being that 12volt systems use a coil that only needs 6volts to run,BUT-they are wired to start on 12 volts for easier quicker starting,and switch back to 6 volts to run. Dell and Claus please correct me if i'm wrong.
Jim K
Scott
12-26-2001 17:51:51
 Re: Re: 12v coil...need a resistor? in reply to Jim K, 12-26-2001 16:48:53
I'm just wondering what your reason was for switching to 12 volt? Now what are you going to do for electrical parts down the road? For some reason the companies think the 12 volt coil is a great idea, if you really want to go through with it now you have to buy a 12 to 6 volt resistor and use your old coil to save your points and put a rubber boot over the hot post of the alternator. If i were you i would return the kit and fix what your problem was on the tractor to begin with.
