Order Ford 9N Parts Online
9n headgasket
Don Pa
04-17-2000 13:19:31
Can anybody help me with how much to tighten the head bolts on my n . also anything else i should know about changing the headgasket. thank you
Russ in SoCal
04-18-2000 23:33:07
 Re: 9n headgasket in reply to Don Pa , 04-17-2000 13:19:31
The Vintage Ford Tractor Resource page has torque specs for everything from head bolts to owner's jaws. Try Link
Tom(Pa)
04-18-2000 11:51:26
Hi Don,
Go to www.n-series.com and click on cylinder head. This gives you the torques for both the head bolts and the studs. PLUS...It even shows you in a picture the correct tightening sequence.
From far western Beaver county,
Tom(Pa)
ZANE
04-17-2000 18:35:16
I can't remember the torque for the head bolts but I think it is about 70 foot pounds. If I am wrong someone will correct me.
The main thing about replacing the headgasket is to be extremely sure that every bit of the old gasket and any other material is off the surfaces of the head and the block deck where the gaskets seals. I use a gasket sealer such as 3M's High Tack or Copper Coat gasket sealer.
Run a bottom tap through all the holes in the block where the bolts will go back. brush the threads of the bolts with a bench brush to clean all the gook off the bolts. Put a little WD 40 etc on the threads of the bolts before installing them.
