Any opinions on electronic ignitions?
Stever(oh)
04-16-2000 19:59:14
It's been about a year since the N got to running good, and now it has a miss under load, so I figure its time for points and condenser. I don't want to do this every year, and I thought I heard talk of an electronic ignition module for a 6v N. Is there a favorite among us here on the board? of is it just better to leave it alone and change the points and condenser every year. There's no show to this tractor, it's all work, so I don't care about being a purist. We thank thee.
monte manuel
07-20-2002 08:27:15
 Re: Any opinions on electronic ignitions? in reply to Stever(oh), 04-16-2000 19:59:14
Im trying to find the problem on the ignition switch on a 1990 ford f-150. I need the wiring diagram from the switch to the cylinoid.
EVE YIANNAKIS
03-12-2001 08:35:15
Please can you help me I am looking to change the iginition on 1959 Mercedes Benz Model 220S to electronic ignation and need an optical switch assembly and ignition coil. Would you be able to tell me where I could source this from. The car is rounded shape 'Pontin' - engine No:M180III/180.924N7513514. Any assistance would be greatly appreciated.
Thanking you,
Eve yiannakis
george s
04-17-2000 11:02:21
Installed one in my 12V 661, works great,worth the money. Got mine from Genesse(sp)? Get one and you to can say, What's points and condensor?
JamesC.
04-17-2000 07:58:12
If your tractor has a front mounted distributor, there is not one available. At least I have not found one. Someone please prove me wrong.
Many years ago I built a transistor ignition for my car. It used the points to turn on a transitor to fire the coil. This setup can work on an 8N with front coil. The points can last a long time this way but you still have to clean them. The schematics can be found in 70's era electronics magazines.
The ideal way is to replace the points with an electronic sensor like is used in cars and currently available ignition kits. Don't know why I have not found one for my front coil tractor.
Earl2
04-17-2000 10:00:10
 Re: Re: Any opinions on electronic ignitions? in reply to JamesC., 04-17-2000 07:58:12
At the bottom of p. 21 in the Spring issue of the 9N-2N-8N-NAA Newsletter, there's a note that their next issue will feature "Electronic ignition for a 9N!" Here's their link:
Earl2 with the link
04-17-2000 10:02:28
 Re: Re: Re: Any opinions on electronic ignitions? in reply to Earl2, 04-17-2000 10:00:10
Since the link didn't seem to post, here it is.
www.N-News.com
AL@NC
04-17-2000 05:24:04
Go to Parts and Supplys on this board and look at Genesee Products. I put one of there modules on my F250 4X4 and one on my Jubilee. They work great.
Nolan
04-17-2000 03:38:49
Every instance of an engine being converted to electronic ignition has been a plus in my experience. From lawn mowers to tractors and high performance racing engines.
