2N rear wheel new oil seal leaks?
Mike W
12-09-2001 09:48:34
Hi guys
I have installed new oil seals and bearings,but the right side still leaks even after I installed a new one the second time.
anyone have ideas why and how to stop it?
thanks Mike
Jerry (Loudon, NH)
12-10-2001 03:40:26
 Re: 2N rear wheel new oil seal leaks? in reply to Mike W, 12-09-2001 09:48:34
Wish I knew for sure, but I think I've heard that if you don't have the shims set up right the seals can leak.
Jerry is correct/Old George
12-10-2001 13:05:15
 Re: Re: 2N rear wheel new oil seal leaks? in reply to Jerry (Loudon, NH), 12-10-2001 03:40:26
And I think you will find there should be at least one on each side of the brake backing plate. They serve a sealing purpose like gaskets also and am told are the cause of 90% of "rear seal leaks". Hope this helps.
Alan Esch
45 2N kit 183513
Ron IND
12-09-2001 15:28:04
Hey Mike, My 8N did the same thing, the way I stopped it was to put a big ugly wrench on it and had my nephew stand on it( 140 lbs) and jump on it a little. I thought it was tight but that tightened it a little more, wha la no more leak. Ron
