Order Ford 8N Parts Online
8n hydraulics
Mike Good
04-16-2000 17:36:34
Does anyone know of a way to boost the lifting power of the 8N 3pt. hitch?
Kim
05-25-2000 06:33:21
 Re: 8n hydraulics in reply to Mike Good, 04-16-2000 17:36:34
Test, please ignore.
Nolan
04-17-2000 03:28:20
The simplest way is to increase the hydraulic pressure. You could do this by changing the point at which the pressure relief valve pops off. This will also increase the likelyhood of failure of other hydraulic components due to the increased hydraulic pressure.
Depending on the resources available to you, you can machine a larger hydraulic cylinder and piston. This will decrease lift speed of course. You could also change the geometry of the lift arms to increase leverage. This would result in less lift height of course.
Overall though, the lifting capacity of a properly operating N is more then adequate for their size. Lifting heavier impliments will almost assuredly result in damage or destruction to the tractor. Weigh carefully what you desire, and consider a larger tractor if you really need more lift.
bg
04-16-2000 17:51:22
You can't make it lift more than it's designed for. 700-800 lbs. If your pump is in good shape, as well as the cylinder and piston, it will be able to lift all the tractor is designed to lift. If it's worn out, rebuild it. Pump pressure can be measured.
