2N not turning over
Jeff R
11-26-2001 16:14:48
have not had any problems starting before still has the six volt system last two starts were late evening starts and I noticed sparks coming from the area under the battery box can any-one give me a starting point? thanks Jeff
David in TX
11-26-2001 19:48:55
 Re: 2N not turning over in reply to Jeff R, 11-26-2001 16:14:48
My 9N recently did the same thing. Thanks to help from this forum, I was able to determine that my problem was with the starter drive not properly engaging the flywheel. It was basically bound up, and when the juice hit the starter it could not turn. The result was sparks. A new starter drive assembly did the trick for me - $60 at a starter repair shop here in Ft. Worth. Take a look at the archives on starter removal and installation, as this made the job much easier than I thought it would be. Good luck. Dave
