Brian..... ...with compression in the 58-72 psi range, I'm amaized that you can even start it. Ford specs 90 psi min. Are you sure you are doing compression check correctly? At least 5 revs, wide open throttle, all sparkplugs removed. Do a dry and then squirt about 1 teaspoon of oil in sparkplug hole and do it again for 5 revs. Write it all down. If'n NO increase, burned exhaust valves, if'n MAJOR increase (20+ psi), worn rings and time for a rebuild. When was the last time you checked the headbolt torque? 65 ft/lbs. Theres a correct sequence to tighten headbolts, starting from center of head and spiraling outward. Loose head bolts can cause overheating and low compression and consequently low power. You CANNOT adjust frontmount timing with engine running (no timing marks). Make certain you have your ignition firing order correct, 1,2,4,3 CCW. Lots for you to check, but remember, you can't make a silk purse outta sows ear. That is to say, if'n you don't have good compression, engine ain't gonna run well no matter how many tune-up parts you throw on it..... ...Dell
