Order Ford 8N Parts Online
8N Engine Rebuild Kits
John Janitor
11-14-2001 20:44:18
Well, it has come to pass that our 8n is up for a complete engine overhaul. The machine shop that is doing the work is reccomending using a Tomco sp? engine rebuild kit. I would appreciate any feedback on this kit and or where to purchase one. If you think this kit is not good, what other reccomendations might you have? This is a 1948 8n with a front mount distributor. The machinist is also suggesting putting .090 sleeves in the motor.
Thanks a lot,
John
Greg
11-15-2001 05:43:48
 Re: 8N Engine Rebuild Kits in reply to John Janitor, 11-14-2001 20:44:18
John,
I have used the Tisco stuff with good results. I chose to stay with the .040 steel sleeves in mine. If you choose to go with the .090 cast iron sleeves, your machinist will have to bore the cylinders for them. On the upside, if you ever rebuild again in the future, you will have the option of boring the sleeves oversize instead of changing them out. Hope that "cleans" up any ? you had.
