2N Rear Axle
Troy
10-31-2001 08:52:24
I removed the rear left axle housing last night in order to remove the link pin. It was obvious the housing had been previously removed. When I inspected the axle, I noticed a fairly large (1.5") "chip" out of one of the axle ribs where it meets the differential. All other ribs appeared in good condition and no other apparent damage. Is this common? Should I be considering replacing the rear axle? I am fairly sure the piece has been removed. Also, when I stood the axle housing on the hub, I noticed a small amount of water collecting in the depressions near the link pin. Is some amount of condensation normal? Lastly, I tried removing the center hub to slide the axle out. It just didn't want to move. I loosended the brakes but still no luck. What did I do wrong? Any info is very much appreciated. Troy
llamas
10-31-2001 09:07:08
 Re: 2N Rear Axle in reply to Troy, 10-31-2001 08:52:24
As regards the chipped section of the cast rib - I wouldn't replace the axle trumpet if it is otherwise in good shape. However, I would take a Dremel tool or angle grinder and grind the chipped area smooth, to remove any stress risers which might cause a crack to start or spread.
Remember that these parts were designed in the days before Finite Element Analysis. Iron was cheap, added weight on a tractor was not necessarily a bad thing, and the limitations of the sand-cast process tended to make castings bigger and thicker than the application actually called for.
Water in the rear axle? It's a fact of life. All you can do is make sure that the obvious points of entry (the gear shift lever) are properly booted. But condensation is what it is.
Removing the bearing carrier to slide the axle out can be a bugger. They tend to get themselves well fitted into the end of the axle housing. You can't beat on the end of the axle too hard because the bearing won't take it. There's a trick that involves the use of a couple of handyman jacks to force the two apart. Judicious use of heat on the end of the casting (to expand the socket) may also free them up.
HTH
llater,
llamas
