JB Weld Over Running clutch on?
Gary (MO)
10-30-2001 05:54:59
My PTO shaft must be really worn. New ORC (from New Holland Dealer) is a real sloppy fit (3/16" wobble at end of shaft.) What if I were to shim or jig it up centered to hold it and glue it on (and use the roll pin too)? Don't have any 1-1/8" implements. I assume some heat and a puller would get it off if I ever needed to.
Maybe get one of those nice Ford logo seat covers with the hundred $ I save.
bg
10-30-2001 16:15:08
 Re: JB Weld Over Running clutch on? in reply to Gary (MO), 10-30-2001 05:54:59
Why doncha go ahead and get a new 1-3/8" shaft?That will take care of the worn shaft problem. Then you get a standard 1-3/8 x 1-3/8 ORC.
Gary (MO)
10-31-2001 19:09:42
 Re: Re: JB Weld Over Running clutch on? in reply to bg, 10-30-2001 16:15:08
Why? How about:
Shaft $100.00 1-3/8 X 1-3/8 ORC $60.00
Throw away 1-1/8 X 1-3/8 ORC $60.00
JB Weld $5.00
Steveo
10-30-2001 09:36:01
Are you sure it's sloppy on the INSIDE fit to the PTO shaft? The ORC will appear sloppier than a straight extension or 1-1/8 to 1-3/8 adapter, simply by design. The internal slip mechanism of the ORC causes this.
Ed-Illinois
10-30-2001 06:27:38
What you might have done was get a 1-3/8" to 1-3/8" ORC. Since the PTO shaft is 1-1/8", you need an adapter.
There are ORC Adapters which have a 1-1/8" female end and 1-3/8" male end. I got mine at Farm and Fleet. TSC has them as well.
Ed-Illinois
10-30-2001 06:27:25
