I've searched this N board, but I haven't found anything related to this "unique" problem that I have.When I bought my 9N, it had a new 6-volt battery, a Delco-Remy 12-Volt "one-wire" alternator, and a new 6-volt solenoid (in other words, it was still a 6-volt system). I can't determine the actual alternator model since some of the numbers are ground off. However, there is a stud on the back marked BAT. Immediately above the stud is the letter R. There is a black cap covering two spade terminals on the top. Below the cap, there are two markings: a 1 on the left and a 2 on the right. There is an R below the 1 and an F below the 2. (I think someone on this board said that the R is for Relay and F is for Field and this alternator requires external voltage regulators, but I'm going from memory). Is this a 10SI (17SI) or some other oddball GM alternator? The alternator was wired as follows: a 10 ga wire running from the BAT stud to the ammeter and a wire from the ammeter to the starter keyswitch. There are no other wires attached to the alternator. Here's the catch: in the 6-volt setup, the 12-volt alternator was putting out 6 volts and the ammeter showed a minimum of 10 A-15A (if it took a while to start the tractor, the alternator may put out almost 30A). To be fair, the alternator was putting out 6 volts when connected as indicated above, but over 12 volts when completely disconnected. When I converted the tractor to 12-volt, all I did was add a dropping resistor (about 1.5 ohms), installed a 12-volt Ford car solenoid and swiped the battery from my truck. The 9N starts right up now. When I'm running the starter, the ammeter shows a slight discharge (about 1-3A), but once I turn the key back to run, the ammeter never actually shows a positive charge (I've even tried running the engine at full throttle). The voltage at the BAT terminal of the alternator is 12.47V, however. One of the articles here at YT suggest that on 12-tractors, a voltmeter is better, since these 12-volters don't draw much current (and that as long as the alternator is putting out 12-14V all is OK). Is this ammeter-showning-a-charge-at-6-volts-but-not-at-12-volts a problem? Should I add a voltmeter? Thanks
