2N brakes/sure seals/paint
Jason (CT)
10-09-2001 17:24:05
I've been reading the posts about how to fix the brakes on my '42 2N. I want to add those sure seals but it wasn't clear to me where to get them. If they are on the ytmag.com site could someone tell me what part number? Are those 8N brake shoes the same as on the 2N?
I have another question about the paint. My 2N has s/n 103548 but it is painted red and grey. Is that the correct color? If not, where can I get the right paint?
Thanks folks!
Jason (CT)
10-17-2001 17:15:09
 Re: Re: 2N brakes/sure seals/paint in reply to Steve W, 10-10-2001 07:36:16
Thanks guys. Just got the parts today.
What type of grease did you pack the bearings with? Typical wheel bearing grease is probably too thick to get down in there. Grease gun type grease seems too light. I'm going to do a search.
Jake
10-09-2001 20:55:06
 Re: 2N brakes/sure seals/paint in reply to Jason (CT), 10-09-2001 17:24:05
Walts tractor parts in Mexico MO has all parts for Fords, an on line catalogplus fast delivery. I use them frequently.
Bob (KY)
10-09-2001 18:24:44
should be able to get the sure-seals from your local tractor parts store or dealer. Also you can probably check out one of the sponsors here and find them.
2N brakes are not the same as the 8N.
Red & gray is not the right colors for the 2N. It was all gray. You can check look to the left of this page under the Research and Info at Paint Codes for the right color gray. Also someone may know of other links to more paint codes.
GOOD LUCK
Bob (KY)
