Good Concern - Another reason why the 8N had a voltage regulator - ford learned from its mistake. The cutout relay is a simple device for keeping a battery charged, but doesn't care much about the status of the charging system in general. last winter I used my 2N when it was having a charging problem, for plowing snow. Full Battery, lights on, and the battery would be dead within a half an hour. Dead battery = no sparkies Since then, I found an aftermarket replacement for the cutout relay, which is a true voltage regulator.
It is made by a company that produces model T parts that do the same thing. With this gizmo (as I like to call it) I get a voltage regulator for the 2N without messing around with wiring, extra resistors, or new coil. I have used it on mt 2N for about six months now and haven't had to charge the battery once. A couple of weeks ago, I was behind on the grass cutting so, whil cutting after dark, I ran with the headlights, tail lights, and implement light for about 45 minutes with no problem. After I shut down the tractor, I thought about what shape the battery would be in so I started her back up - no hesitation - battery had lots of juice. I have no interest in the company; my testimonial is gratitude because Dell and others on this board mentioned this product after I went through three cutout relays in a month, none of which kept the battery charged. If you ar going to use the lights on your tractor for more than just driving back from the field after it got too dark to work anymore, I recomend you look into this device good luck ed
