Order Ford 8N Parts Online
49 8N Governor adj?
Daniel.johnston
10-04-2001 07:17:45
First off, I am new to the tractor arena.
I have only had this tractor about a month now. I was using the tractor last week when all of a sudden I could not control the throttle. Disconnected the governor and removed it only to find it shelled out. I purchased a governor kit, (completely assembled) and installed back on the tractor. Operationally checked and could not get the tractor to ideal down with out disconnecting the governor. I have tried to shorten and lengthen the rod between the carb and governor and the same with the throttle rod. Is there an adjustment on the linkage of the governor either internal or external? How can I check this new governor and do I have the correct governor for the application?(The old governor had fly weights but this new one has steel balls.)
dave
10-04-2001 13:55:01
 Re: 49 8N Governor adj? in reply to Daniel.johnston, 10-04-2001 07:17:45
Daniel here's a site on governor overhaul www.si-inc.com/8NOverhaul/governor/
hope it helps goodluck
