Loader Pump Shaft
Gerry
09-29-2001 19:38:03
I need a replacement shaft that goes from the front hydraulic pump to the engine pulley. Mine is 3/4 inch in diameter X 13.5 inches long and I've actually had to shim it another 0.25 inch to keep it tight into the pulley. My dealer says replacement shafts are only 13-1/16 inches long, which would not work. Any idea where to find what I need? Mine has reverse thread on one end and key slot on the other.
Any suggestions will be most appreciated.
Mike OH
09-30-2001 08:35:20
 Re: Loader Pump Shaft in reply to Gerry, 09-29-2001 19:38:03
Gerry, I replaced my pump shaft a few years ago, and as I recall the New Holland dealer had two different lengths available. You might also check to see if you have any adjustment at the base of your pump to allow it to be mounted closer to the engine. The plate that my Wagner loader pump mounts to is slotted giving me quite a bit of adjustment. Good luck.
Would you guys post a pic of the pump and bracket...
10-01-2001 19:34:24
 Re: Re: Loader Pump Shaft in reply to Mike OH, 09-30-2001 08:35:20
A good friend, also an auctioneer, dumped a trip bucket loader on me last weekend at auction. It has no pump or bracket whatsoever, and I'd like to get it up and running before the snow flies next month... Thanks guys... Jess
