Order Ford 8N Parts Online
8N Don't like charging, still
Woodsman
09-27-2001 16:08:37
Help!! I am new to working on my 8N. First, I have been having to charge my battery about every 2 weeks, even though I use it every day. I suspect either generator or voltage regulator. It is a 1950 model. The ammeter stays about 2 units below zero, unless I turn the headlights on, then it goes about 7 or 8 below. I went to Claus' troubleshooting page, but I needed the troubleshooting for dummies page. I guess I need a picture because I don't know which is the Armature on the generator, or if I need to just use a wire terminal connection from the regulator that goes to generator, don't know which one the field connection is either. Any help would be greatly appreciated.
Claus
09-27-2001 17:25:41
 Re: 8N Don't like charging, still in reply to Woodsman, 09-27-2001 16:08:37
The armature (sometimes called gen or generator) is the big terminal on the end plate. Now the field is a little harder to find. There are 2 terminals on top, one is a stud that comes out of the case and is the ground connection. The other is insulated and is the field connection. You may have to remove some grime to get a closer look at it...
Happy Motoring
Claus
