Order Ford 8N Parts Online
8n ford carb
lj
04-07-2000 07:51:52
my 1950 8n has rough idle, runs good otherwise, has new carb,(second one), new manifold, new wires and wiring harness, new 6 volt coil but is converted to 12 volts, new points and condenser, does anyone know why it just will not idle smooth.
THANK YOU
bg
04-07-2000 08:27:13
 Re: 8n ford carb in reply to lj, 04-07-2000 07:51:52
There are other things besides the carb that could be causing the rough idle. Could be distributor shaft wear, distributor cam lobe wear, bad plugs, valve adjustment, or sticking valves, weak valve springs cam wear, bad plug wires, point air gap, timing, etc.
Diagnose each system and eliminate them one by one.
Phil (NJ)
04-07-2000 08:23:56
lJ, I would use a dwell meter and Timing Light to
see if anything is jumping around, bad bushings etc.
Do a compression Test. I always test for sticking
valves first by using the hand crank and insuring
compression is obtained every 2 rotations. Then
using the starter (Carb off) do a dry and wet run
recording numbers. They need to be balanced for
smooth idle
JMHO
