Killed battery now will not start
Blaine
09-15-2001 10:41:37
I accidentily left the switch on my 9n and killed the battery i tried to boost it off of the starter but it will not fire. Any suggestions? (tractor is 6 volt system).
Steve IA
09-15-2001 12:37:11
 Re: killed battery now will not start in reply to Blaine, 09-15-2001 10:41:37
You need some voltage in the battery to create the spark no matter how you try to start it. Try recharging the battery. If you left the key on, you might very well have fried the coil. If it cranks on it's own battery power and you have no spark at the plugs, replace the coil. HTH Steve 8N 169302
BOB[PA]
09-15-2001 17:29:57
 Re: Re: killed battery now will not start in reply to Steve IA, 09-15-2001 12:37:11
I THINK YOUR POINT GOT BURNED----NEED TO REPLACE THEM BOB
