2N Hydraulics Failure (Found the problem)
noff
09-12-2001 07:11:57
I pulled the lift cover last night thinking that I needed to replace yet another Ram Piston on my 2N for hydraulic failure. When I removed the inspection cover and tried to lift I saw fluid pouring from the cylinder. It turns out that I blew out the paper gasket between the ram cylinder and the lift cover where the fluid enters the ram cylinder. There was about a 1 inch piece missing around the fluid opening.
Does this mean I didn't torque it down properly?
TimK
09-12-2001 07:38:41
 Re: 2N Hydraulics Failure (Found the problem) in reply to noff, 09-12-2001 07:11:57
Suggest that before you put things back together, put a straight edge on that part of the lift cover and the housing to make sure things are straight and flat. Also, did you use sealer ? My $.02
AL(Ca)
09-12-2001 08:25:05
 Re: Re: 2N Hydraulics Failure (Found the problem) in reply to TimK, 09-12-2001 07:38:41
On my Jubilee I was told to NOT use gasket sealer on the gasket around the port as it will act as a lubricant when the pressure is applied to "force" the gasket out. I put mine on dry and it is fine.
