Order Ford 8N Parts Online
8N Serial Number Solution
Farmer Tim*8N15
09-09-2001 16:38:35
After attempting various methods of trying to read my lightly stamped serial number on my 8N, I finally found the solution. I first stripped off the paint with a Naval Jelly paint remover, then cleaned off the bare cast iron with mineral spirits and let dry good. I then used Magna-Flux ( a spray penetrant and developer for checking for cracks in cast iron castings ) to bring out the numbers and they were as I had suspected. I had a slight doubt because some days I would "see" a 2 in front of the rest of the numbers which would make it two years older. Also, the casting code says: I167... ( September 16, 1947 ). It helps to use a good magnifying glass, too. Thanks to all the methods suggested here on the YT forum, also.
lars
09-09-2001 18:27:25
 Re: 8N Serial Number Solution in reply to Farmer Tim*8N15513*, 09-09-2001 16:38:35
At least your serial no problems are now over. When I finally got mine readable, it yielded 8N351766. And I've never been able to settle the dispute over whether it is a '50 or '51 based on that serial no!!
Ed Gooding (VA)
09-10-2001 03:35:26
 Re: Re: 8N Serial Number Solution in reply to lars, 09-09-2001 18:27:25
Hi Lars. According to the table from a Ford tractor dealer service bulletin below, you have a '51:
third party image
Hope this helps..... ..... Ed
'52 8N475798
lars
09-10-2001 18:17:22
 Re: Re: Re: 8N Serial Number Solution in reply to Ed Gooding (VA), 09-10-2001 03:35:26
Wow!! Thanks, I really appreciate that. Right from the horse's (meaning Ford's) mouth. Case closed.
