Order Ford 8N Parts Online
8N choke problem?
steve
04-05-2000 05:00:42
I have a 52 8N that I overhauled 5 years ago. For the last three months it seems that it will only run good with the choke half on. I have installed a reman carb because we couldn't get the brass seats out of the old one. It seems that whatever mixture I adjust on the carb, it doesn't help. Any ideas? Also I don't have low idle without severe RPM pulsing. I have checked the sock in the tank, and also changed an inline fuel filter I installed.
Hilltopper
04-05-2000 06:36:54
 Re: 8N choke problem? in reply to steve, 04-05-2000 05:00:42
You probably have a cracked manifold, internal or external. Spray some WD 40 around the manifold and see if the RPM picks up. Cracks are a big problem on old manifolds. New manifolds are about $65.
Timk
04-05-2000 06:48:28
 Re: Re: 8N choke problem? in reply to Hilltopper, 04-05-2000 06:36:54
I agree. Running with the choke is almost sure to indicate an air leak somewhere. Take a look also at the gasket area where the carb is connected to the manifold, as well as loose manifold nuts.
