3 point hitch wont go down
mike
08-25-2001 17:30:25
Help,I have a 1952 8n,The 3 point hitch raises fine but once up it stays there.The only way to lower it is to take the plug out of the right side and release the oil.Ive had the top off twice adjusted the linkage once my self,that didnt work.Took it off agian and took it to the ford dealer reinstalled it,same thing.Ive had the pump out disassembled cleaned and reinstalled that didnt change things either.Ive made and checked every adjustment in the I-T manual I can find.Still nothing seems to help,anyone got an idea.When you raise the hitch and it reaches the top the engine labors a little and there is some turbulance in the oil around the pump.When you push the control lever down the engine runs eaiser and the turbulance around the pump stop but the hitch stays up.Seems like the oil in the piston and lines cant return to the resivor.Any advice would be great.Thanks in advance Mike
B B Stacker
08-27-2001 09:01:57
 Re: 3 point hitch wont go down in reply to mike, 08-25-2001 17:30:25
Mike, Ive had this same problem. My problem turned out to be the small ports in the exhaust valve sleeve being plugged. I had to drive the sleeve out of the pump housing to clean them. Hope this helps.
