2N fan belt replacement
Joel B.
08-25-2001 00:23:02
There is some kind of "drive coupling" on the nut that holds the crankshaft pulley on. I don't know if the belt will clear this. How do I get the "coupling" off the pulley?
Thanks for any advice,
Joel B.
Dave Smith
08-25-2001 05:29:35
 Re: 2N fan belt replacement in reply to Joel B., 08-25-2001 00:23:02
I damaged my old belt trying to get it by the crank bolt. Jack up the engine just enough to take the weight off. Loosen the bolts holding the front axel sadle to the engine and slide it forward just enough to get clearance. you don't need much. Worked for me.
Dave <*)))><
Darrel (ok)
08-25-2001 00:51:00
The drive coupling you speak of is for a hand crank starter. It and the hex bolt are made together as one piece and screwed on like a standard bolt. You should be able to work the old belt or new belt around it without to much trouble, it does not need to come off.
Dell (WA)
08-25-2001 00:50:39
Joel..... ....that "drive coupling" is usually what operates the front end loader hydraulic pump. Since it didn't mean anything to you, I suspect that your tractor does not now have a FEL. You just unbolt it and remove the drive shaft and fish your fan belt around where it all belongs..... ...Dell
