4stroke
Jim EubanksTN
08-19-2001 08:39:45
Since new cranks are being manufactured for Ns, has anyone given any thought to a 4" stroke version? With the v8, using a 49-53 Merc 4" stroke crank immediately ups the torque, hp and cubic inches form 239 to 255. On a N it would give an additional 8 cubic inches and more torque. Stock rods could be used and std bore Merc pistons would work.
Dell (WA)
08-19-2001 12:06:58
 Re: 4stroke in reply to Jim EubanksTN, 08-19-2001 08:39:45
Jim..... ....If'n you just increased the stroke, the pistons would probably hit the cylinderhead. You'd need new type of pistons with differnt rod pin spacing. Then you'd have to worry wheather the rods would knock the bottom of the cylinder linings or sides of the blocks.
Lets see.....8 cu/in increase on a 119 cu/in block is about 6.7% increase. And at 23.2 drawbar hp that might make 24.75 hp for a 1.55 hp increase. Not hardly worth the money for your causal every day user..... .Dell
Jim EubanksTN
08-20-2001 03:30:43
 Re: Re: 4stroke in reply to Dell (WA), 08-19-2001 12:06:58
Dell,
The Merc 49-53 pistons are for the 4" stroke and are 3 3/16 standard. They would work off the shelf. With the longer stroke there would be more torque. It makes a big difference in the V8s and I believe it would help the N. Not make it "go faster" but add HP and torque. As for the bottom end swing, am not sure.
