Order Ford 9N Parts Online
3-brush generator on 9N
Jack B.
04-03-2000 07:27:32
Can anyone tell me if there's a way to make a 3-brush generator go to full output so I can check to see that it's working properly?
Mine registers about 4 or 5 amps and stays the same all the time. I think this is normal, but would like to know more about them. Is there a site that has info and maybe a schematic?
--Jack B.
Jack B
04-04-2000 07:31:23
 Re: 3-brush generator on 9N in reply to Jack B., 04-03-2000 07:27:32
Thanks for the info. I also found the article on this site. It's got diagrams (Pictures), which are easier for guys like me to understand.
--Jack B.
Elvy
04-03-2000 16:08:17
If it is a three brush generator, there is a slotted, High/Low adjusting "screw" on the rear cover. It moves the third brush inside the generator. Turn it with a blade screwdriver. Do not force it past the stops (1/2 - 3/4 turn). Max safe current is 11 amps. It might charge up to 20 amps, but not for long.
Five amps might be a bit high if it is going to run all day, but OK for intermittent use. If the battery uses too much water, reduce the charge rate.
Elvy
Jim WI
04-03-2000 10:54:20
If you're seeing 3 to 4 amps into the battery with the tractor running, it's working correctly.
The 3-brush generator doesn't have regulation -- it's just adjusted to a charge rate that will keep the battery charged under normal operating conditions. It's really a primitive system.
Tod
04-03-2000 10:09:03
The sponser of this board has article archives. The archives should answer your questions.
