Order Ford 8N Parts Online
8N OVERDRIVE
HLM
08-13-2001 08:31:10
I have a question, Years ago my uncle had a 8N with over drive and underdrive, So had 12 Speeds Forward and 3 Reverse.
I am looking at a 8N that has the overdrive and not the under so has 8 speeds forward and 2 reverse. Is this normal in this tractor.
There also is no Serial Number stamped where they are suppose to be located. Does have front distributor. Would this happen if the block had be changed.
Jim.UT
08-13-2001 09:51:15
 Re: 8N OVERDRIVE in reply to HLM, 08-13-2001 08:31:10
Both the over/under combo (like the one you remember) and the over only or under only aux transmissions were aftermarket or dealer installed options. So yes, both are "normal" but not necessarily common.
As for the serial number. It may really be there. Some of them seemed to get stamped very lightly (end of the shift, tired hammer arm?) so you may have to do some serious degreasing and/or paint removal to see it. However, a block replacement would have the same effect, ie, no serial number.
Here's a quick link to the site referenced by Jim(FL)
Jim(FL)
08-13-2001 09:40:55
HLM
I recommed this web site to help you ID the tractor
Link
Great Site!!!
Good Luck, Jim
