Stuck lift
js8n
08-06-2001 09:43:08
let me post this again.This weekend I went through the hydraulic pump,cleaned it,looks GOOD.Put in new oil gaskets,new cylinder and NAA piston.The lift comes up kinda slow but then jams at the top.Lots of pressure on the arms and I can't move them back down.If I move the touch control lever I can see a slight up/down movement,even with the engine off.Noleaks that I can see,and the relief/safety valve isn't stirring up the hyd.oil.So,what am I missing??Is it something simple???She lifts up fine,but won't come loose to drop the lift arms.I did not change the relief valve yet.Should I???Thanx guys,for hearing me out!
rasputen
08-06-2001 10:04:19
 Re: stuck lift in reply to js8n, 08-06-2001 09:43:08
js8n,
Did you do the quadrant adjustment?
I think it is more responsive now and you need to do the qudrant adjustment. My FO4 is at the barn so I forget what they call it. If you have the video, Guy shows you to put it in Draft, raise the arms and loosen the 4 bolts on the qudarant and adjust till the arms just start to come up w/o hesitation.
maybe this will help?
bd
noff
08-06-2001 11:09:18
 Re: Re: stuck lift in reply to rasputen, 08-06-2001 10:04:19
I read about the quadrent adjustment in my FO4 and it says to loosen the 4 bolts and adjust the quadrent. I loosened the 4 bolts holding the quadrent to the lift housing but my quadrent on my 2N won't budge an inch. is it just seized up? or am I loosening the wrong bolts?
js8n
08-06-2001 11:03:42
Thanks!-I'm going to try this agin.I thought it was adjusted but another time around can't hurt.I'm surprised more people haven't run into this,or maybe I just have a really messed up pump!
