12 Volt Coil Resistor Part Number (Here we go again)
Brads8N
08-05-2001 17:51:13
Checked the archives and couldn't find what I wanted. Here goes. 48 8N with 12 Volt conversion. Single wire to altenator. 12 Volt Coil. No resistor in-line with coil other than the one on the dashboard. Was Brushoggin for about an hour (running perfect) and it started to miss and backfire under load. Shut down for about an hour ran fine for another 20 minutes and started to miss and backfire again. I think it is the coil. Have plenty of gas. Archives say to put a ballast resister in-line with coil but never gave a value or part #. Bought one that is a Borg Warner Part #RU4. Is this correct? Guys at parts store thought it was. Won't start now with or without the resister and I have power to the coil but no sparkies. What voltage do I need to see at the coil with and without points closed to make Lil Red Happy? Thanks in advance.
Phil (AZ)
08-06-2001 13:59:59
 Re: 12 Volt Coil Resistor Part Number (Here we go again) in reply to Brads8N, 08-05-2001 17:51:13
Brad, You say you have 12V Coil, (assume front Mount) The Resistance of the coil should be ~3.0 Ohms if its 12V, or ~ .7 Ohms if its 6V
If its truly a 12V Coil (3.0) ohms you need to use 2 (OEM) in "parallel" and Voltage at the Coil will be 10.V - 11.V (The resisters split the current and half the Resistance to ~ .75 Ohms "HOT".)
If its a 6V Coil then you need a RU100 (or equiv that starts at ~ 1.5 ohms) and the original Oem Ballast in "series" and the coil Voltage will be 2.4V to 3.3V
Hope this Helps,
Weedwacker
08-06-2001 05:22:10
third party image
Hope this helps. It's from www.nseries.com
Andy - Hammond, LA
08-05-2001 18:43:50
Here is some info as I have come to understand it - I am learning this stuff too!
If your coil is truly a 12V coil (make sure that you dont have a 6V coil) , then you don't want to be using the "voltage reducer RU-100" - you only want to be using a ceramic ballast resistor. The original dash "reducer" cuts to V too much. Check with the points opened and closed. More important than "part numbers" is the aggregate capability of the resisitor under amperage load. With proper current flow, you are looking at 10.5V-11Vs at the top of the coil. Also check and make sure that you jumper out the ignition switch which is known to cause lots of problems with time/heat related symptom problems.
Here is info on the points as I have come to understand it...
The coil fires when the points open. The reason it fires when the points open is that there is a charge in the primary windings of the coil when the points are closed and as soon as the points open the magnetic field that was present around the primary windings immediately collapses and the magnetic field energy is channeled through the secondary (high voltage windings) and the high voltage is created.The condenser is in the circuit to act as a "buffer" to prevent the charge in the primary windings from arching across the points when they open.
The high voltage that is generated in the secondary windings is discharged through the rotor to the electrode of the distributor and then through the spark plug wires to the center electrode to make the "sparkies"
Well hope that is all correct. (grin)
Regards,
Andy
