12v from 6v
Jimbob
08-03-2001 13:16:09
I need to run a small 12 volt sprayer from my n It has a three brush generator. Is it possible to put the generator in series with the 6v battery to make 12volts. Not charging the battery while spraying should not be a factor since the battery alone will keep the tractor running for uite some time.I can't think of a reason this wold not work.
Matt 45 2N
08-03-2001 20:24:12
 Re: 12v from 6v in reply to Jimbob, 08-03-2001 13:16:09
Intresting idea ,I dont think it would work How are you planning on hooking it up?
Richard Fazio
08-03-2001 19:07:28
I think your idea could work, the problem is the generator is held to 6 volts by the battery. Doing what you want would leave no control on the generator. It would put out more than 6 volts. You would probably fry the sprayer. Then you could get another control for the generator to keep it a 6 volts. Again as said a good deep cycle 12 volt battery would work best. Probably last pretty long on a charge. What's the ampere draw on the sprayer? Sears deep cycle batteries are 105 amp hour.
Dave Smith It Wont Work
08-03-2001 18:09:56
DC current can't be transformed. Actually it can but it would not be worth it. His best bet is to get a deep cycle marine battery and a charger. He can also convert to 12 volt. His reason is one of the fiew reasons to do so. Still better off with a battery and charger. He could also make up a Rube Goldberg and use a small AC gas generator and a battery charger to power the pump.
Dave <*)))><
bg
08-03-2001 15:07:22
Just buy a 12-volt battery and a charger and hook it up to your sprayer. Use it til it runs down and then recharge it at night.
jimbob
08-03-2001 16:15:59
 Re: Re: 12v from 6v in reply to bg, 08-03-2001 15:07:22
I don't want to but a new batter and charger.
Just was wondering if there were any reasons this would not work.
bj/8N/mt
08-04-2001 07:17:22
 Re: Re: Re: 12v from 6v in reply to jimbob, 08-03-2001 16:15:59
You gots a twelve volt battery in the pick up or in momma's car, or in the lawn tractor right? You can't drive both at once, right? What's the problem?
Your mileage may vary
Dan
08-03-2001 17:10:35
Try it --- then tune it up for maximum smoke !
bg
08-03-2001 17:34:47
 Re: Re: Re: Re: 12v from 6v in reply to Dan, 08-03-2001 17:10:35
I'm not an engineer, but I think a battery is a storage device and a generator is, well, a generating device. I don't think putting a 6 volt generator in series with a 6 volt battery will give you 12 volts. If you put 12 volts into your 6 volt battery, you'll have a melt-down. That's why these things have voltage regulators, 3-brush variables, cut-outs, etc. Why not rig a transformer to step the 6 volts up to 12?
I still think a $30.00 battery and $15.00 charger is cheaper than a $100 starter. But, like I say, I'm not an engineer.
excuse me, I meant generator, not starter.....bg
08-03-2001 17:35:36
 Re: Re: Re: Re: Re: 12v from 6v in reply to bg, 08-03-2001 17:34:47
