Re: Fuel valve wheel screw
Tim PloughNman
05-27-2020 04:52:49
That's the problem -you don't know you lost the knob til you get back to the barn to shutdown for the day. The knob screw didn't use to come off, but the newer aftermarket Sediment Bulb Valve Stem will lose the knob in the field if you don't put a dab of ThreadLocking compound on the #8-32 screw. The screw also takes a star washer. Turn knob fully CW to close when not in use and 2 Full Turns to open. Fully Open gets the last 1 gallon reserve in the tank.
FORD TRACTOR FUEL SEDIMENT BULB ASSEMBLY:
Third Party Image
SEDIMENT BULB VALVE ACTUATING KNOB:
Third Party Image
Third Party Image
Third Party Image
Tim Daley(MI)
