Jubilee optional live power
jimmyjack
07-15-2001 10:25:55
How do you troubleshoot the bypass valve for the live power lever? It works in live power mode, ie. it shuts off ground speed with the pto running, but when I move butterfly bypass valve 1/4 turn nothing happens. I thing when in bypass the tractor should be like a tractor without livepower. Could I disconnect the hydraulic line and blow air through it without hurting anything?
Patrick/OR/n-tiques.com
07-15-2001 21:49:45
 Re: Jubilee optional live power in reply to jimmyjack, 07-15-2001 10:25:55
Nice to hear that someone else has one of these!
Mine takes a little while to completely diengage. When I shut the bypass valve off, it still reacts to the lever for a few minutes and then it begins to operate correctly. Same way when turning it on... it takes a few minutes for the pump to charge the lines... I guess!
Good luck with it! These are very rare and you cannot get parts for them.
Patrick
www.n-tiques.com
